switch temp johnson 85ESL73M
Dali30
Does the engine run without this switch installed? what does it do?
Daviet
Re: switch temp johnson 85ESL73M
You can run the engine without the temp switch, but if the engine overheats you will not know it until it seizes up. The purpose of the switch is to sound a horn in the control box if the engine overheats before the engine is damaged. You should really have the warning system operational.
JRegier
Are you talking about the half-choke temperature switch on the top of the block near the hook or the overheat temperature switch in the engine head?
Dali30
Daviet answerd my question,will install it.thanks:)
Daviet
As JRegier asked, you are talking about the switch in the cylinder head, correct?
Dali30
yes..
