Switch wiring
Brokeback Johnson
Setting up a wiring harness with no control box for an 82 50 Evinrude and have been using keyswitch wiring information from this fine forum. I am within one wire of completing the job. Here's the formula:
A - double purple
B - red
M - Black yellow on the raised terminal
C - Purple white
M - Black
S - ???? yellow???
My red plug harness does not have a yellow wire. There are white, tan and gray wires, none of which have a ring terminal. I'm guessing white instead of yellow for the start terminal?
Thanks for any help
bktheking
Re: Switch wiring
S would go to the yellow and red according to my 82 50 hp remote electric start diagram which goes to the starter solenoid.
A- is purple and red
The rest is correct.
PS- it calls for a neutral start switch between the ignition and the solenoid, FYI
Brokeback Johnson
Re: Switch wiring
Perhaps the harness that I am using is from an older setup? It did not come with the 82. No yellow and red with this one.
bktheking
Re: Switch wiring
Harness on the motor, not the controls, just look for the small wire going to the solenoid.
SparkieBoat
Re: Switch wiring
yes trace the wire from solenoid, connect it where the yellow red wire goes. make sure it was not cut short, every harness I ever seen had that yellow red wire. but I aint seen everything I guess.
