Switching from trailering to storing in a saltwater slip... what is a "must do" to protect bravo3?
acarleson
I run a b3 on a trailer. Switching to a salt slip. I've heard nightmares about b3s in the water as far as corrosion. I hope they're overblown but just in case I want to do EVERYTHING possible to reduce corrosion.
Trying to build a comprehensive list of all the things that I must, must do that actually help, and maybe learning about the things that people say to do but that don't actually help all that much.
Obviously new anodes and regular checking is #1. What else?
thank you all
Bt Doctur
making sure the factory bonding is intact , monitoring your zinks for wear, adding additional bonding wires to the cylinders, making sure the steeering arm bond is connected to the inner transom and the transom bond is connected to the engine.
Additionall make sure you do not have an electrical bonding issue on your dock, test for stray current in the water
With boat connected to shore power use a digital meter and connect Negative to battery ground. Connect the positive side to something like the mercruiser PROBE . Meter should read between
Salt, Polluted or Mineral Laden Water Areas:
750 - 1180 Millivolts with Digital Meter
In addition to what is covered above
On the boat side, barrier coat and bottom paint
On the out drive and props, a protective coating such as prop speed
On the issue with bottom growth, a good hooka rig or a tank setup for monthly bottom cleaning
Chris1956
Honorary Supreme Mariner
The outdrive will need antifouling protection. I would recommend you brush on a coat of Trilux. I have found the spray-on A-F paint to have lousy coverage.
Lou C
get ready to suffer with painting that damn thing every year, it is a job I dread more and more
and yes, Chris is right, the spray doesn't last, depending on your area for fouling, I have found that brushing on 2 coats lasts the season.
And spray the engine oil pan and timing cover with rust prevention spray like fluid film or similar, every season and check all your hose clamps for any raw water leaks, they will rust things like crazy.
