I didn’t use a bypass or blocking regulator. I’m using a Holley 12-803 set to 5lbs. Is this ok.Great work and congrats!
Question:
did you use the bypass or blocking fuel regulator?
Question:
Your good to go, and like Scott said your won't hear it and even if you do it's fineI didn’t use a bypass or blocking regulator. I’m using a Holley 12-803 set to 5lbs. Is this ok.
You can run 10 - 12 BTDC with good fuelThanks
I haven’t touch the timing yet. Both the TBI and carb are set to 8 deg TDC. I will sea trail it and see what it does under a load.
That’s where mercruiser takes the 12 v from the purple 1409 will also need a ground wire for choke , I just attached mine to carb bodyI have another question
I wired the purple/white wire to the top left post per wiring diagram. Checking voltage. This post only puts out 7 volts to the choke. Holly And Rochester carbs only need 7 volts for the electric choke. The edelbrock 1409 needs 12-14 volts. Can I add the purple/white wire to the solid purple wire that is on lower left post. It puts out 12 volts and runs to the ignition, coil, alarm buzzer, and solenoid. Per the wiring diagram I don’t see any inline diodes that would interfere with it.
On a sea trail I gained 300 rpm over the old setup at wot. I discovered that I could probably get another 200-300 rpm getting the throttle linkage adjusted when I got home looking at things. Still fine tuning things.
