SX-A Lower Drive Gear Oil Change?
DO2G
can someone tell me where the drain bolt and and upper bolt when full on a SX-A drive?
ThomW
Lower drain plug is behind the prop I believe. Middle plug is under cover on lower(you need to remove it) and there is a dip stick plug on top. At least from what I can remember. Always pump oil up from bottom.
