SX-A trim cylinder help
RAN H190RS
Have a Four Winns with leaking SX-A trim cylinders at rod end seal. In the process of rebuilding them, have apart & awaiting seal kit. Considering replacing the brass cup/oring seals where hydraulic lines attach (part no. 3889431) while trim cylinders are off the drive. Has anyone replaced these, and how did you remove the
brass cups? Thanks for any help
