Bigdave196
Thread starter- Joined
- Apr 13, 2009
- 120
Ok, I just picked up a new toy at a deal I couldnt pass up. 1997 Blue Water Monte Carlo with a Volvo 5.7 300hp (F.I.) and the SX drive on it. I have not had this newer boat in the water yet, but I am familliar with it and I have seen it out on the water many times. I own the same boat but a 1995, and I have repowered it from carb'd 260hp 5.7L , to a carb'd 350hp 5.7L and for 2 years and over 200 hours I have never had an issue with over powering the Alpha 1 Gen 2 with my 19* 3 blade Stainless prop.
Hours on the new boat is about 600, and the drive in netural is a little "tighter" to spin at the prop. On my Alpha 1 drive you can easily spin the prop and it spins freely for a second or two before it stops, the SX drive it has drag to it and almost stops immediatly. So here are my questions,
1. I have heard that the SX drives are smother shifting, could this have any relativity due to a form of clutche in the drive?
2. Is this a known issue on prop "drag" for the SX drive?
3. How hard would it be to either fix a suspected issue and if this is a common issue, am I looking at a gimble bearing and U-joints, or ???
4. I have heard that SX drives are stronger than Alpha 1 Gen 2's, Is this true? If so how strong are they and what kind of power can they handle?
5. Are parts hard to get, and are they pricey?
All replies are greatly appreciated and thank you in advance.
