Re: sx cobra rattle/vibration noise
Do a search here there was a guy a long time ago that had simular issue. I have a 99 SX drive and occaslly mine does the same thing. (rattle at idle) Always when it has been run and lube is thin and goes away when it goes in gear or revs go up. It started to made the noise when i bought the boat used at 50 hrs on it and now has over 400 hard hours and the same. Lots wake boarding in and out of gear and heavly loaded. Does not always do it and gear lube has always been changed at 50 hrs intervals, never has any dust and always looks new, but change it regually cause oil is cheap and outdrives are not. I think it is caused by slight backlash preload and the noise when thr idle is rough (mine is GL carb motor). Someone smater than me in the other post said it was slight mis adjustment of a shoe that moves the gear.
