The Dougler
Thread starter- Joined
- Oct 11, 2009
- 70
I ordered a Solas RBX prop from Iboats however I can not get it to mate with the drive correctly. My old prop slides on and off the prop shaft with ease and no need to force. The new one I can not get all the way on. I don't want to force anything (i.e mallet) because I don't think it should need that.
Also should this thrust washer come off before the one in the solas hub kit goes on? I tried to pry it off gently but it would not budge, however I did not put much pressure on it in fear of messing something up. I'm thinking it's best to pick up a pulley puller and use that if this is indeed supposed to come off.
This is with both on which I do not think is correct.
I did some test fitting with the new prop and hub kit, and I found that it was difficult to get it down the prop shaft I could only get it within about 1/2 to 3/4 of an inch being all the way on, not even far enough to come in contact with the original thrust washer. Does it just need to be tapped home with a mallet and 2x4 across the prop?
Here are the vitals:
Drive: 2004 SX-M1
Prod# 3868891
Serial# 4202100073
Volvo Prop# 3850302
New Prop is Solas RBX 9513-143-19, and the Hub kit is RBX-105
I've called it quits for tonight but would like to complete this tomorrow after work. What do you guys think?
Drive: 2004 SX-M1
Prod# 3868891
Serial# 4202100073
Volvo Prop# 3850302
