Sx gear oil change shouldn’t be this hard
River Pete
Seriously, shouldn’t I be able to take the drain plug off with a screwdriver and minimal effort? So far I broke one screwdriver and left a nice mark with an impact. It seemed I am just ruining the slot at this point.
It’s not reverse threads, right?
Any tips from y’all?
Impact and BFH. Swing the BFH with authority
BRICH1260
Purchase a drag link socket. Google it, it fits the grove perfectly and does not mar. It can also be adapted to an impact driver if a little force is needed.
GMTK
Maybe a little heat on it? There is a rubber gasket on the drain screw.
River Pete
Soooooooooooo?
Yup, had an old chisel laying around that needed a little grinder work to get it perfectly flat. Gave it to’er and that’ll work. Waiting on my new plug thanks to the previous attempts. 👍
Too bad it couldn’t have been literally any other head screw…
Donald0039
One wonders why it's not Torx or Allen head.
But it could be harder. A VP duo prop requires you to remove both props (using the tool) and the drain plug is behind the back prop.
QBhoy
Biggest thickest flat head you can find…lock it hard into the slot with your inner knee..use a shifting spanner on the screwdriver flat (or better stil..if you get a screwdriver with a hex on it to get a spanner on properly)…she will loosen fine.
