Sx-m outdrive raw water nipple inlet o-ring size ? ,Volvo is out
kccoe
What is the size of the 0-ring that goes on the plastic raw water inlet housing that connects the raw water hose from the impeller to the lower unit. Volvo is not aware that it is boating season they are out stock for the nut that goes along with the inlet water nipple besides the 0- ring. Just can't believe that Volvo does not keep these products in stock. First and last Volvo penta that I will own. Going back to mercruiser at least they stock parts
evantful
Do you know the part number you were looking up, or the serial number for your transom shield for the SX-M? There are multi versions that are similar but use different O-Rings and Nuts.
Right now Im not seeing a out-of-stock for most of them
kccoe
3868891 Sx-m. 1.60 serial number 42020776371 product number 3868844 transom 5.0 gxi-d. Engine family 3vpam 5.0 gxi
evantful
Ok thanks for the information.
Here are the two part numbers you need:
O-Ring: 3852535
Nut: 3852534
You can go to volvopentastore.com and insert the part numbers
They show both in-stock
And just to confirm we are talking about the same thing, heres the Gimbal part diagram with the two parts in question circled.
Also the nut in question, it looks like a normal nut just its big and plastic, correct?
kccoe
No Title
Here is a photo of broken tube on wood righ of hand
