Lou C
- Joined
- Nov 10, 2002
- 14,524
The good news is once you get it fixed, if you are going to keep the boat as long as you remove it at the end of each season it will come off. Just be aware of developing problems esp noises from the area right behind the coupler. I’m sure that this was a failure of the bellows which rusted the gimble bearing and caused it to rust to the drive shaft and/or coupler. BUT, you can be sure this was making noise for a while. A good set of ujoints and gimble bearing should be totally silent. So following up on noise issues and pull the drive once a year and you should have no chronic problems. Mine still has the 33 year old original ujoints and I replaced the gimble bearing once back in 2005. 100% salt water use moored in salt 6 months every season. So see you can make these work in the harshest conditions just maintain it without fail.
