Symptoms of reeds not sealing properly?
tedious
What are the symptoms of one or more reeds not sealing properly - is it obvious? I am in the process of rebuilding my carbs, and I'm trying to decide whether it's worth the time to pull the manifold off to check the reeds - they look OK from the carb side.
Tim
iwombat
Re: Symptoms of reeds not sealing properly?
If your engine is spitting fuel back out the carb bodies you can suspect your reed valves.
tedious
And if it's not, no worries? Mine isn't...
Tim
F_R
Tim
Reed problems on modern motors are extremely rare. Don't even worry about it unless you have good reason to suspect. Mouse nests and dirt daubers are a couple of good reasons.
tedious
Thanks - think I'll leave well enough alone!
Tim
