sync and linc
jeff6898
Is doing a sync and linc after a carb rebuild necessary? 1979 85 hp 859999R
HighTrim
Re: sync and linc
Simply a carb rebuild? No
That is not to say that your motor does not need a linc n sync. We will need a little more background.
tashasdaddy
Re: sync and linc
if you have not moved any of the linkage, no. to be sure the motor is set up correctly, yes.
Nandy
Re: sync and linc
If you have a tach a sync/link is so trivial I cant see why not do it. It does take a bit of time but then you know you have a properly adjusted motor.
