Synthetic Engine Oil???
vincechig1975
I am toying with the idea of using a synthetic engine oil in my newly rebuilt 470 and the 4.3. Now I understand the differences between the two of them , but is it recommended versus using a standard petroleum, and the price is a big difference as well. Lend me some ideas and thoughts. Vince
dubs283
Re: Synthetic Engine Oil???
you can use whatever oil you like
merc recommends 25W-40 in all sterndrive engines, catalyzed engines require mercruiser full synthetic catalyzed engine oil
second choice is SAE 30
as long as you maintain regular oil/filter changes, using conventional or synthetic that meets the wieght requirements you should be fine
mark1905
:facepalm: :facepalm: :facepalm: :facepalm: :facepalm:
:facepalm:
Don S
If you don't want to use what the manufacturer suggests, then here are a few links to other oil threads to help assist you in choosing your oil.
They all come down to the same thing, people posting something like
"I use ___(Fill in the blank)___ and it works great"
http://forums.iboats.com/showthread.php?t=451752
http://forums.iboats.com/showthread.php?t=445976
http://forums.iboats.com/showthread.php?t=436377
http://forums.iboats.com/showthread.php?t=300620
http://forums.iboats.com/showthread.php?t=426361
http://forums.iboats.com/showthread.php?t=423766
http://forums.iboats.com/showthread.php?t=357663
http://forums.iboats.com/showthread.php?t=319916
