umblecumbuz
- Joined
- Sep 25, 2004
- 1,062
Re: synthetic oil ?
Unless I'm reading it wrong, Nevd is saying that manufacturers keep stats at low figures, because if they raised the stat opening temperature, salt deposits would seriously increase.<br /><br />But because ssea salt has such a flat solubility curve, you'd have to raise the motor temperature way way up before that started to happen, so IF manufacturers are deliberately putting in low temp stats, there has to be another reason.<br /><br />There are plenty of other salts present in water, each with a different solubility curve, but usually they are present only in minute quantities, and would not make any real difference to crud buildup.Nevd said this: It is to stop this salt buildup that outboard manufacturers limit the thermostat temperatures to such a low figure
