T H Marine Aerator Spray Head/Wash Down Combo fitting AHVWD-90; anyone use one?
ajgraz
Anyone use a T H Marine Aerator Spray Head/Wash Down Combo fitting, part AHVWD-90 (or -92)?:
http://www.thmarine.com/product.cfm?PRID=178
http://www.iboats.com/Aerator-Spray...0734022--**********.658203072--view_id.168925
If so, I've got three questions for you:
1) Can you really turn it to COMPLETELY "off," as in no flow at all, not even a drop?
2) The threaded end on the valve side of the fitting, is that std garden hose thread?
3) Does the thing seem sturdy? Like it would last a few years?
Thanks
tashasdaddy
Re: T H Marine Aerator Spray Head/Wash Down Combo fitting AHVWD-90; anyone use one?
t-h has a great reputation, on it's products.
ajgraz
Guess I'll soon find out. Ordered one up from Cabela's (only $9.99).
(iboats out of stock :( )
I'm looking to use it "in reverse" by mounting it "backwards" in a Starboard panel (along with a marine twist-lock socket, switch and fuse holder), mounting the panel in the sidewall of my splashwell, hooking my Rule pump (on a submerged transom bracket) to the threaded side (with a garden hose thread connector), then running hose from the hose nipple side under the splashwell to my removable bait tank. The valve is important so I can shut 'er down and prevent water siphoning into the cabin when I don't have the bait tank in the boat.
I'm hoping it will clean this hose and wire mess up a bit:
(Yes, the holes in my transom are filled; I had relocated the eyebolts)
