T n T issue
cbeam2
We were out yesterday and the T N T quit going up. It would go down and the motor would run when you hit down. It made no sound at all when you hit up.
It had been working all day up till the point it quit. The motor was down all the way so we limped back to the launch. I kept hitting the button on the way back and it started to work again. Got it home and seems to be working fine now.
Any ideas? What can I check?
thanks Chuck
Boss Hawg
Re: T n T issue
thanks Chuck
Sounds like your switch-
You have more than one?
If so do they all act the same :confused:
cbeam2
Re: T n T issue
I thought the same thing at first but, I have 3 switches and none would work.
Chuck
jonesg
Re: T n T issue
You can pop those relays open, they're not glued, squeeze the contacts together see what happens. Look for cold solder joints.
cbeam2
Re: T n T issue
Well crap, I can't believe I totaly forgot to include motor info.
It's a 1990 Johnson 150GT. Where are the relays located?
chuck
