T@T failure
jerryjerry05
My boat sat all summer way too hot to fish and upon starting I tested the T@T systems.
​The port motor would go down but not up. Replaced the relay and fixed the problem.
​Put the boat in the water and helped my neighbor retrieve anchors used during the storm.
Got back to the ramp and tried to lift the port motor and now neither up or down was working??
​Unhooked the front hyd. line and lifted it and took it home.
Got to testing and couldn't figure it out.
Tested everything I could.
​Then I pulled the top of the trim motor off and found a broken connection in the cap.
The Green or down lead is connected/ soldered to a points like switch.
It had broken and wouldn't make connection.
​Luckily I have a bucket of T@T parts and have 3-4 good motors.
Now that I'm looking I might try to repair the slow leak down??
