spitfisher
Thread starter- Joined
- Apr 19, 2008
- 27
Hello, my t top is mounted in 6 spots, 2 to the center console and 4 feet attached to the deck, not sure if there is a backing plate, helicoils or inserts for these four feet. problem a couple of the screws have become loose to the point that 2 of the feet actually move a tiny bit. This will only get worse I realise.
Question- to reseat these screws for good! is there an epoxy or adhesive that you would recommend,? Also should I consider a tiny bit bigger screw as well? they are very close to stripping, not much grab to it when I tighten.
Obviously the tee top takes apounding when in rough water- this is the likely cause.
Thanks
Thanks
