landingzone
Thread starter- Joined
- May 24, 2009
- 4
My 2007 T8 HT trim/tilt is not functioning. I tried to lower it and it went down a little. I tried raising and it moved up a little. Then it no longer would move. I can hear a faint click when the up/dn switch is activated in either direction (relay?). I see no obvious problems. Probably is the trim motor but I was wondering if others had had the problem and knew the fix? Thanks.
