1216bandit
Thread starter- Joined
- Aug 18, 2008
- 214
The engine is a 1984 3 litre mercruiser 130 with electronic ignition conversion. Tach has worked just fine till the last time out. It wont indicated any higher than about 1300 rpm and does return to idle rpm but stays there when the engine is shut off. If I turn the ignition on it will drop down to zero, turn the ignition off and and it climbs a bit. I just cleaned all the connections at the tach but nothing changed. I would like to check the signal source at the engine but with the electronic ignition I'm not sure where its taken from. Any tips greatley appreciated! Thanx....Dan
