Alas, Russ is probably chasing ghosts again. 1972 100 HP Johnson,Teleflex Tach. Everything works perfect except, when at idle I put it in forward gear the tach needle jumps up 150-200 RPM. The engine speed does not change.I have verified the RPM with a hand held tach. Back to neutral or reverse and the RPMs go back down and agree with the handheld. It will do it in or out of water and is pretty consistant. It does it with or without the throttle cable connected so I'm sure its electrical and not a rigging problem. No other changes in any other instrumentation. Any ideas??<br /><br />Russ In Texas
