tach and other wiring
willard887
I bought a 1996 Johnson 50 controls and all. I hooked the tach up all system check lights come on then go off. All that checks out. I have two extra wires not attached to anything on the harness now. Are these for a voltmeter and trim gauge?
Joe Reeves
Re: tach and other wiring
It would help if you would describe the wires in detail..... color, stripes, whatever.
willard887
OK there are two sets of wiring one set is black, purple, white. The other set is black, purple, gray.
Chris1956
Black purple grey are for a standard (not System Check) tachometer. Black is ground, purple is +12VDC for accessories. I think the white one is trim sender.
willard887
So if I buy a trim gauge it will possibly work with the existing wiring?
Chris1956
I would verify the motor has a trim sender and the white wire is the right one. Of course, a water pressure gauge is much more useful than a trim gauge, IMHO. You can trim by feel and sound.
