Re: Tach and prop issues
Last weekend with my 16' I ran 5200-5300rpm on the tach with the 19P, I didn't gps it though. But I did look at the motor and it says 4600-5500rpm range, rated 85HP at 5,000rpm. So if my tach is right maybe 5200-5400 is as high as I should run it. I keep forgetting to take the clamp on tach. It will pull about 100rpm more with synthetic lube in the LU but I ran out this year. I don't know what the weight of this 16' is to compare with yours, also if you have weight in the boat or wet foam that will slow it down. I still have some foam to take out/replace.
