Tach hook up for 1984 70 hp Rude
Steve135
Hi I have asked this before and forgot. I think the answer was to connect it to any yellow wire at the terminal strip? Isn't there a wire that runs in the harness to the key switch, or to the throttle. I couldn't find a ref. in the wire diagram for that year motor.<br />steve
Hooty
Re: Tach hook up for 1984 70 hp Rude
The tach wire is the gray wire. There should be a three hole receptical on the control for the tach plug.<br /><br />c/6<br />Hooty
Marc J.
Is it best to use the connections on the controls or go straight to the motor? How could I obtain a plug to interface with the controls?
Hooty
I know Teleflex makes a cable that goes from the tach to the receptical in the control and I'd bet OMC does too but you could wire it all the way back to the terminal strip. If you do, do the next guy a favor and run a gray wire. ;) <br /><br />c/6<br />Hooty
mncafik
And I believe the Tach should be set to 6pole for that 70.....<br /><br />Mike
Steve135
Thanks I will go and see if theres a plug first but I think not. I will rn a gray wire to the terminal strip.<br />steve
rickdb1boat
Might already have the gray wire up under the console. Take a peek...
