tach installation
red_chaser
How do you install and where do you buy tach for my engine?
70HP Johnson
70EL77S
Thanks for your help.
Challenger84
Re: tach installation
bump
I would also like to know.
I also have a 70hp Johnson model #J70elcte
wilde1j
Your control unit may have a three conductor plug-in pigtail. If so, get a mating harness from a BRP dealer.
Tachs typically have three connections:
purple: switched 12vdc
grey: sensor or pulse feed
black: ground
jtexas
I got my teleflex tach at basspro, and they also had a ready-made wiring harness for it. If you have the OEM control box, there's a 3-hole socket covered by a rubber boot just below the throttle tension knob.
If you can't find or don't want to buy the plug-in harness, you can always DIY using the wire colors described above.
The tach posts will be labeled "GND" ground, "SND" sender (pulse), "LT" gauge lighting, connect it to your helm lights, and I forget what the 12V power post is called....
