Harritwo
Thread starter- Joined
- Oct 4, 2011
- 586
The SeaRay Tach is the original tach installed in the boat. When i first start the boat, the tach will read erratically for several minutes. I have checked all connections, removed the wires from the tach, cleaned all connections, reinstalled all wired. Verified the tach is set for 4 cyl and still have issues with the tach. It will read at least 1000 rpm higher than the engine is running and bounce around all over the dial for a while. When it finally starts reacting right, it reads acccurately compared to a hand held tach that i have.
Does anyone have any suggestions where to troubleshoot or what to inspect/test/replace?
Thanks.
Thanks.
