Tach not working on 1985 Black Max 150 XR2
strtbobber
I've replaced the rectifier and still no tach. Where should I go from here?
Barnacle_Bill
Re: Tach not working on 1985 Black Max 150 XR2
If your charging system is working properly and all the wiring to the tach is good then the tach must be bad.
strtbobber
With motor not running, the battery showed 13 volts. With the motor running, the battery showed 12 volts. How can I confirm better whether or not it's charging properly?
You already confirmed that your charging system is not working. When motor is revved to high idle, voltage should rise. It appears your voltage doesn't rise. Check for AC voltage on yellow stator wires.
