tach not working
Andy in NY
1970 evinrude 85 hp
tach is an outboard tach set to pole 1 (4cyl)
have pos and neg running right from battery, and grey wire from inside controller to sig on tach, but get no reading what so ever. where do i start troubleshooting?
jtexas
Re: tach not working
try the "6p" setting.
Does the tach peg zero when connected to battery? If not, confirm voltage on your wiring (to rule out wiring fault), then replace the tach.
Is the outboard charging circuit working? If not, the rectifier is faulty (tach signal comes from rectifier).
Can you read any AC voltage on the gray wire with the engine running? If not, look for open circuit fault on the gray wire. Otherwise replace tach.
Silvertip
The tach sense lead comes from the charging system and not the ignition system so it not # of cylinders dependant. The charging system outputs 6 pulses/engine rev so as suggested, try that setting.
