clemsonfor
- Joined
- Sep 19, 2005
- 1,011
I have been around for some time, not posted in a while but i have not had any problems. This is good and bad as it does not allow me to help others.
My common question which i have seen before is. I have a 1990 johnson GT 150hp.
What is the color of the tach wire under the hood? Is it connected to that bar on the starbord side of the motor? And what is the wire color on the ignition switch related to the tach?
The tach will sometimes work then it will just drop to the bottom like its off, sometimes it will then jump back into action but then die again. It usually will register as the motor runs but at a certain point usually a min or so after will just die off.
-Nate
-Nate
