Tach not working
powrguy
I have a 1987 V4 90HP Evinrude and cannot seem to get the tach working. I have the ign terminal supplied from the ignition, the grd has the blk ground wire to the negative bus, and the gray wire runs to terminal 3 (3rd from the top) on the terminal strip on the motor. I checked continuity from terminal 3 there, to the tach itself, and it's okay (continuity checks good). I have the selector on the tach set to 6P.
Any ideas what I can do?
thanks
boobie
Re: Tach not working
Either a bad tach or a charging system prob on the mtr.
m75rlg
Is the charging system charging?
I had the rectifier replaced when my tach wasn't working and the system wouldn't charge. Solved both problems.
powrguy
I'm going to replace the regulator/rectifier. The only other symptom (other than tach not working at all) is a "High Voltage" alarm on my VHF radio. Hopefully, the 1990 90HP regulator/rectifier I found will work on my 1987 V4.
