consultpsc
Thread starter- Joined
- Nov 4, 2009
- 4
Hello,
I am new to this site.
I have a 1990 Evinrude XP 150 on my 1992 Ranger boat.
Recently, the tach began to malfunction showing loss of RPM then jumping back up to normal readings. The tach finally quit working completely.
I have been researching how to troubleshoot the tach verses Regulator/Rectifier (RR) and I'm not sure I understand how to do this.
Someone called Seahorse on this blog had tried to explain how to do this but I'm not sure I have performed the test correctly.
I turned the key "on" and took a voltage reading at the grey wire terminal screw, my fluke meter showed somewhere around 9 vdc.
I then disconnected the PUL grey wire from the back of the tach and took the reading again, it was now showing about 11 vdc at the grey wire terminal screw. I then disconnected the wires from the grey wire terminal screw and measured voltage just a the grey wire from the RR and it still showed about 11 vdc. I measure the other two grey wires which were connected at the terminal and they showed a very low voltage perhaps .6 vdc.
Is this telling me that the RR is bad?
Is there any other tests that I can perform to further evaluate this problem?
I can not run the engine right now because the boat is in my garage now.
Any help would be appreciated.
Consultpsc
Consultpsc
