The new tach I have replaced seems to work up to 4000 rpm then it goes to zero. I have replaced the old tach with a new one as the old one never worked when I bought the boat. It also seems to go to zero if I try to trim the motor, I have check the connections all the way to the engine and everything seems tight, I have also checked continuity between all wires from engine to tach. Thought I would get out on this forum and ask if anyone has run into similar.
