Streffpilot
Thread starter- Joined
- Aug 22, 2012
- 144
Hey, got a question for you guys, should I be able to pull a tach signal off of either side of the stator (2 wire)? Or should just one side be sending a signal???? To be more clear, I tried both sides of the stator, and can get a signal IF I switch the rectifier leads. So only one side of the rectifier is allowing a tach signal. Is this normal????
