Tach Question?? Won't zero at pwr up
Pst76
Have a 85 470 Mercruiser in a 19ft Four Winns cuddy. Have been restoring boat all summer and now gotten to finalizing a few items. <br /><br />The tach is not working and I believe may just be bad. <br />Before I replace wanted to ask for second opinion.<br /><br /> Symtom is when I switch the key on Tach needle goes up instead of zeroing out. I checked wires and looks to be hooked up correctly unless somthing in the harness is wrong. <br />Is there a polarity issue or somthing reversed or could it just be a faulty tach?<br /><br />Thanks for any feed back
KRS
Banned
Re: Tach Question?? Won't zero at pwr up
Define for us what "goes up" means? goes from below -0- reading to 1 or so? or halfway or redlines? Does it work once boat is running?
Pst76
With no power to Tach I have a zero reading. As I turn ignition switch on/only. Needle goes up to approx 800rpm mark and stays there. <br /><br />When engine is started I get no change. Stays at 800 rpm. No reaction on tach regardless of engine rpm change. Shut everything down and gauge goes back to Zero.
Pst76
Thanks tommays. great info. will test tonight. Break out the clip leads....
