Tach reading almost 3000 rpm at idle before dropping
badrano
Got home with the boat and fired it up to flush it out. Tach jumped to almost 3000 as it started up and then dropped to around 1000 after a few seconds. The engine was at high idle with TKS hissing away
Any ideas of why the tach would read almost 3000 rpm when the engine is at idle then drop off to around 1000?
achris
More fish than mountain goat
These tachos are 'unsprung', meaning they will wander to any place they like (rarely zero) when there's not enough voltage to drive them properly. My tacho will bounce around the 4,000 to 6,000 (and beyond) if the battery voltage drops while cranking...
What you're seeing is perfectly normal...
Chris.....
