Tach seems off
JoshOnt
So new boat, took it out on Sunday and max rpm I got was 4100ish, I looked on the prop to see markings and I can't seem to find any. The prop is in okay shape but could use replacing in the spring. The boat is a 1977 crestliner 550 witha 85hp merc on the back. Any advice on getting the rpm up to speed?
64osby
Have you checked the compression? Done a drop cylinder test?
Sounds like you may a weak cylinder or running on 3.:confused:
JoshOnt
No but I will, also the fact you even think of that before the tach being the issue worries me a lot since I can't do work on the motor.
JoshOnt
How would I go about testing the accuracy of the tach?
64osby
Hooking the motor up to a known good tach. You can buy a "Tiny Tach" pretty cheap and use it.
