tach sender wire?
ebsworj
So i got a new Tach. installed in my boat that didn't have one before but I don't know which wire is the sender. I have a 1994 18' Bayliner capri w/ a 1994 Force 120.<br /><br />The Seloc manual doesn't say or if it does I can find it.
ebsworj
Re: tach sender wire?
Someone has had to have wired in a tach on here?<br /><br />Any ideas how i could test for it without breaking somthing?
Moody Blue
There should be a gray wire that runs from the rectifier on the motor (gray wire will connect to the same terminal as one of two yellow wires), through the throttle control box and out again via the tach harness from the control box. Use an OHM meter to check for continuity from the rectifier to the terminal on the tach harness to be sure it is the right wire before hooking it up to the tach.
ebsworj
Thanks I'll try that! But before i do what does the recitifier look like on the motor? Am I going to see a gray wire attached to it?
Realgun
Thats funny My 88 says on the sticker on the motor that the Tach is Purple.<br />Your lucky that 94 is a 12 pole alternator. These older Force have 20 pole and the tachs are hard to get. Or at least the look you want.<br />But I got me 1 anyway. :)
Moody Blue
Can't say for certain what the actual wire color is but if the mfr's follow the BIA or ABYC guidelines then the tach signal wire should be gray. Here are two images of the electrics for your ref. Not sure which version you have. The rectifier is #17 on first diag and #36 on second diag.<br /><br />
<br /><br />
<br /><br />Hope this helps.
mikebc
I think my tack is shot, it worked 1/2 the time until yesterday, now nothing. I checked all the connections on the back of the tach, good ground, good 13.5volts, and I get a variable voltage on the gray wire, from 6 volts up, depending on my rpms. The needle just sits at 0 on the tach. Is the variable voltage normal, and if so what is the norman range?
mikebc
Does anyone know what voltage on the sending wire would equal what RPM's. I just checked my marina, $140 for a replacement tach. I was thinking of building a digital replacement in the old tachs frame, cheap and it would look the same, except have a digital read. Any thoughts or commements?
Moody Blue
E-bay has tachs all the time for as little as $20.00 new. Usually lots to choose from. Got mine for $26.00 and works like a charm. I would have paid over $120 at the dealer.
ebsworj
ebay is great, I got a entire set new from Faria w/ stainless rings for $109
ebsworj
not yet. I'm still wiring in my amp and sorting out other issues. I'll post when i figure out if its the gray wire.
