I found a Faria tach that shows 1-6 on back ,but then I notice little writing that says 4 cycle only. Would tach still have all settings and some not work? It has the # 6 setting which I was told is what's needed.
go to faria and check under support.they are different in that for your motor you use position 5 not 6 like other tacs made by others!most faira tacs will work for either 2 or four stroke you just set differently but check the site to make sure.i have one for my etec and its set for position 5 and is dead on .
