Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,055
Just acquired a 2002 115 2 stroke. Tach inop.
Checked voltage and ground at tach and ok.
Ohmed grey wire from tach to bayonet connector inside engine adjacent to rectifier-regulator module....continuity ok...did find connection to appear corroded....shined it up. Haven't run engine since so don't know if that was it.
Voltage output from rect-regl ok.
If voltage is ok, could the tach output still be bad.....do not have schematic of reg-rect? I understand that the tach signal is just picking off (sampling) the rectified half waves from the rectifier section and the tach counts the peaks....if so, what is there to fail on that?
Do you need an oscilloscope or a fancy multimeter with a video display to read the signal? If DCV on a multimeter how much voltage? Probably a voltage divider inside module to cut the voltage to something in the digital range.....5v?????
Manual is on the way so no help there yet.
Thanks,
Mark
Thanks,
Mark
