I have a ?99 merc 60hp bigfoot (2-cycle) and just noticed that the tach has stopped working. This is on a 24-foot pontoon, and I just had the motor put on the boat end of year. I checked the wires going to the Gauge. It has 12V and the Gray wire goes into the wire harness. What should I be measuring on this gray wire? When I measured with a DC voltmeter, it was all over the place. I opened the motor and did not see anything loose inside. (The wire harness goes into a plug at the back of the motor.). Also, when I first start the motor (starter running) you can see the needle moving, but then once the motor is running, the needle is at 0. I also noticed there is a gauge on the dash with PSI marked on it and that moves as the RPM increase. What would that be measuring? (I was going to replace that gauge with a gas gauge).
What should I check first? This did work, and I don?t know when it stopped working. I am going to take it to the marina next week, but thought perhaps someone can tell me what to check. IE some connector inside the motor has wiggled loose.
Any advice would be helpful before I send it to the shop.
