I have a 1978 35hp Johnson 35EL78R motor on my pontoon that has a Tachometer and battery meter that were not hooked up. The battery meter was simple but there is no grey or grey striped wire at the instrument panel for the the tach. Being that I have a manual choke on the motor I decided to use the electric choke wire from the harness. I disconnected it from the choke and connected it to the yellow-grey wire coming from the stator on the connector block right above the choke solenoid.
This tach is so cheap it doesn't have a zero adjustment and it sits at about 200 RPM with motor not running. The existing tach only has a 1, 2, 3, or 4 pole choice (no six pole that most of the comments I've read say that I would need to use). At 4 the tach gets buried, at 1 the tach varies from 1100 to 4500 RPM with motor running out of gear parked at the dock. When in gear the throttle moves a bit farther so I may even bury this tach but I didn't have time to check it out (mesquitoes were starting to swarm). Set at 1 the tach seems to be getting twice the actual RPMs (I don't have a tach test meter to test the accuracy out). I'll try the 2 & 3 settings tomorrow.
Is it possible that this 1978 35hp motor has less poles than I've read for Johnsons or is there no way I am going to get this tach to work accurately with this motor?
If not, what is a good, cheap ($20-$40) tach to use?
also:
I'd like to hook up a car stereo and pair of speakers, can this motor supply enough juice to charge the battery, run the navigation lights, instrument lights, and the stereo?
How about a microwave oven, air conditioner and hair blower . . . (just kidding)?
Thanks in advance!
also:
Thanks in advance!
