Tachometer Bad?
ziggy2
Farina tach needle Is pegged beyond 7000 and will not operate. Is there a way to determine if tach is bad or there is a problem on the sender end?
achris
More fish than mountain goat
Remove the sender wire (should be grey unless you're not working on a post 1981 Mercruiser), and see if the tacho reads 0 with the power on.
What are we working on? (engine, not boat)
Chris......
Fun Times
Also you could try tapping on the gauge with power on to see if it frees up and also try Exercising a switch on the back of the gauge a few times while ensuring to put the Arrow back on the matching engine cylinders your boat has… The gauge should generally have marks on it somewhere suggesting the number of cylinders.
ziggy2
Chris......
Tach reads beyond 7000 with key off and jumps slightly towards 7000 when key is turned on. Removing the signal wire made no difference with key on or off tach stayed at beyond 7000
achris
A cheapie off eBay?
I find the tacho, despite being the biggest instrument on the panel, the most useless. Oil pressure, coolant temperature, even the voltmeter, give useful information that can be acted upon. What the engine speed is, is entirely dependant on how fast you want to go.
Chris....
nola mike
A cheapie of eBay?
Chris....
And how loaded the boat is, and what prop you have on there. Trim gauge is most useless.
achris
On any given day you can't change the loading or the prop. They are part of the 'fixed data' package. You can only change the boat speed using the throttle. Tacho is nice and pretty and, totally 'unfunctional'...
Ayuh,..... Welcome Aboard,.... Sounds like a 2 stroke outboard tach,.....
QBhoy
Hi. I’ve seen this happen loads. Also seen them go back to working normally once you start the engine and give it a flick. One of my boats that spends most of the year in storage does it all the time on the faria gauge. Right at this moment…it’s sitting showing 1500 rpm…but I know if I go use the boat…it will sort itself out as soon as the engine starts.
ziggy2
Decided that tach was toast. I purchased a new one on ebay which I am hopeful will work ok. Size is ok and has pulses instead of pole settings. Mine is a 12 pole setting so I assume a 6 pulse will be ok. Thanks for all the feed back.
achris
Pulses is for outboards. Make sure you get a tacho that suits a stern drive...
