Tachometer differences?
Dave1027
Can somebody tell what the actual difference is between a tach that is intended for an outboard motor and one that is intended for an I/O? Don't both types have a selector switch on the back for differing amount of pulses?
GA_Boater
Re: Tachometer differences?
Generally speaking, ignition triggered with a switch for number of cylinders (I/O) or stator triggered with a switch for number of poles (O/B) and runs on the stator generated AC. There are variations, of course.
What are you trying to do?
Dave1027
I like the tach that is for the I/O better but I have an outboard motor.
foodfisher
I know nothing! but it sounds like you like the square peg and want to put it in the round hole.
GA_Boater
Why? Styling or something else? What tach are you looking at? And what O/B do you have?
Dave1027
Well, it's styling plus scale. My original tach goes up to 6K rpm and the 100 hp Merc has a max rpm of 5250. All the outboard tachs I see for sale go up to 7K rpm. The I/O tachs go to 6K just like my old one. I guess it won't hurt anything to have a 7K tach. I just thought I'd ask.
GA_Boater
A lot of the major instrument makers have the same style tach in both O/B and I/O models.
Dave1027
Can you post a link to a 6K rpm tach for an outboard? I'm not finding any.
GA_Boater
Do you have other gauges you're trying to match?
Dave1027
1988 100 hp Merc 2+2 4cyl. I'm going to replace all of the gauges. Tach, Speedo, fuel, trim, volt, temp.
GA_Boater
I would just get a matched set. Going to a 7K tach is no biggie in my opinion. And no, I haven't looked for a 2 stroke 6K tach lately.
