i have a 1974 mercury 85hp 850 inline 4 that i am trying to hook up a tachometer to. I bought an aftermarket tach. Fiara i believe. i looked at the wiring diagram and the sending wire for the tach should be a light brown wire / brown wire coming from the main harness out of the engine which runs up to my console. the same harness has all the starter / key wires. i hooked up the tach with power and ground and the wire for the sending signal but i get now readings.
how can i test the wire to see if i am getting the right reading to pick up RPMs. Should i look at voltage or ohms?
