CaneCutter79
Thread starter- Joined
- May 24, 2009
- 454
1979 Evinrude V4 85hp (model 859995R)
I have recentlyt rebuilt my motor. I just replaced the tachometer with a Quicksilver tachometer. Brand new, in box, (not used). I have tested the wiring for ignition source (12.67volts), ground (12.67), and sending unit source (about 4volts). SO the tach has a signal getting to it. This is the second tachometer I have replaced. The last one didn't work out of the box new either.
Will a weak battery or bad battery cause this issue? I'm replacing the battery. Just throwing that out there just in case.
Is there a simple test I can do to find the problem? I'd really like a working tach. It's set to 6 pulse by the way.
