I recently purchased a SunTracker pontoon with a 25 HP Mercury outboard. The tachometer doesn't work. How do I find out if the tach is bad or something else. I seen other forums which says there should be a rectifier and a voltage regulator. I know where the rectifier is but don't see a voltage regulator. The serial of the motor is OG376600 and is a 1996 25 EL. Can I test the tach at the back of it for a siginal from the motor and if so which wires do I connect to multimeter. Any help would be appreciated.:'(
