Daniel1947
- Joined
- Sep 22, 2010
- 267
89 V6 150HP....tach is not working... all wires hooked up and ground and +voltage to back of tach. Gray wire from sender connection on tach back to bullet connector at regulator shows continuity. Is there any way of determining whether problem is with tach or regulator. Other gauges and charging system all operating normally. I know I can get a tach for $50 - $70, but if it isn't the tach it is money wasted since most places won't accept returns on used electrical parts. I am sure there must be some type of "pulse signal" from the regulator, just not sure I can read it with a VOM.
Thanks to everyone in advance as is usual,
