I wanted to know will an I/O tach work on my outboard engine? if so, what do i have to do to make it work.
I/O Tachs go up to 6K RPM. If you know you won't be hitting that, as long as the tach has a setting on the backside for O/B apps, it will work. Farias do.
Yes you're correct, its a 6k rpm, and its a faria alsodo u know what application i need to put it on for my 1997 Merc. 150hp offshore 2 stroke?, On the back the gauge has setting of 1,2,3,4,5,and 6 but its faded so i dont know what number to set mine for..
Rob,
Look on page 3...http://faria-instruments.com/site_manuals/IS0012u.pdf
Don't know if that tach will work...![]()
Report back on your findings...Thanks, Im going to try it tomm, hopefully it will work.![]()
